Author Topic: degauss  (Read 4208 times)
nullb0y
  • Slow In Fast Out
    • WAT Racing
degauss
« on: December 01, 2002, 11:30:17 pm »
how would i go about degausing a television
Slow In Fast Out
M6A4TS
  • Last login:August 25, 2005, 02:28:52 pm
  • Leader of the Ewoks
Re:degauss
« Reply #1 on: December 17, 2002, 07:38:49 pm »
Don't know too much about this but on most TV's they degauss on every power down, hence the crackling noise.
mattv
  • Last login:June 10, 2022, 06:33:25 am
Re:degauss
« Reply #2 on: December 19, 2002, 01:09:17 am »
Most TV sets have a degause coil built in so each time you power up it should degause. in the case of particuarly strong magnetic fields this may not be enough to cklear up the discoluration and you may need to dcegause manually with a degause wand.
You can buy one from Happs I think, but they aren;t cheap.
DIsclaimer: drunk
redeye
  • Last login:January 01, 2003, 02:19:22 pm
  • I'm tired of Looking
Re:degauss
« Reply #3 on: January 01, 2003, 12:17:33 pm »
 ;)  Check out Sam Goldwasser's TV Info. Lot's more info than you will want to know, but right to the point.
http://www.repairfaq.org/REPAIR/F_tvfaq.html
Brunnen-G
  • Last login:April 23, 2010, 09:26:00 am
  • Need more space
Re:degauss
« Reply #4 on: January 03, 2003, 07:57:06 pm »
www.mcmelectronics.com sells a much higher quality degaussing coil for about $30.  I used both it and the smaller one like Happ sells, and the larger one is well worth the cost.
To use, turn on the monitor then turn on the coil and move it over the entire front of the monitor for a few seconds, then move back away from the monitor while moving the coil in large circles.  Once it stops affecting (distorting) the screen, turn it sideways and turn it off.
Side Arms, Slam Dunk, Xybots, Arachnid Galaxy darts, Pac Man Plus, Dr. Who, Gauntlet, Centipede cocktail, Hyperball, Tempest, Star Wars, Xevious, Super Hang On, S.T.U.N. Runner, Galaga, Space Duel.
SNAAAKE
  • -Banned-
Re:degauss
« Reply #5 on: January 03, 2003, 08:11:42 pm »
Does it REALLY work? ???
I got this black spot on the lower right side of my screen while moving the cab to fix a computer problem inside and next time a turn it on...BOOM....the lower right side is little dark.not noticable when played(only in white screen) but i bought brand new and want things to be NICE. :-\
Which should i get for a 25" monitor? ???
Brunnen-G
  • Need more space
Re:degauss
« Reply #6 on: January 03, 2003, 08:14:36 pm »
90% of the time, the large coil will do the job.  If it's a bad purity problem, you may need a TV tech to adjust it.
Try turning the cabinet 90 degrees and see what happens.  Occasionally some displays just don't like facing in a certain direction.
Make sure there are no magnets near that corner of the screen (speakers, fans, coils, power supplies, etc.)
SNAAAKE
  • -Banned-
Re:degauss
« Reply #7 on: January 03, 2003, 08:17:44 pm »
well...there are magnets on top(speakers).but thats about it.i will likely buy this big one unless things just go away by itself :o.
Thanks for the quick reply :).
