Author Topic: Help With Omnistick Prodigy with 1st Cab Build  (Read 1165 times)
mumbles
  • Last login:January 25, 2024, 09:20:01 pm
« on: May 11, 2005, 09:41:11 pm »
Hello,
i am building my furst arcade cabinet and
Tiger-Heli
    • Tiger-Heli
Re: Help With Omnistick Prodigy with 1st Cab Build
« Reply #1 on: May 12, 2005, 07:11:16 am »
Does anyone have some info/instructions on mountign these sticks in a  wooden control panel and how to wire them up to an ipac4??
Mounting - for lack of a better pic - see http://www.retroblast.com/reviews/joysticks/prodigy.html  There should be a template with the sticks, but basically, cut a square hole, drill four holes for the mounting studs and secure it.
BTW, I recommend replacing the stock nuts with nylon-insert locking nuts - they tend to work loose over time (or you could use a dab of the non-hardening thread-locker on them).
Wiring is the same as any other joysticks - see http://spystyle.arcadecontrols.com/index8.htm (use stranded rather than solid wire (unless you are soldering instead of using Quick Disconnects).
Also note : It is important to note that the joystick's switches are opposite, when you push up on a joystick the shaft below pushes downward, when you push left on the joystick the shaft below pushes to the right, and so on. Give it a try and you'll see, then wire the switches accordingly.
Also what size hole do I need to drill in my panel for the buttons from groovygamegear - I presume it 28mm diameter??
Technically, 1-1/8 or 1.125 inches which is slightly more than 28 mm but less than 29 mm.  I think there is enough slop in the 1-1/8 hole that 28 mm would be fine.  Try it in a piece of scrap wood first to be sure, though.
