Author Topic: Best tool for cutting Happs Bezel  (Read 2929 times)
Dagg
  • Last login:June 05, 2017, 04:23:59 pm
« on: May 11, 2005, 02:25:44 pm »
My HAPPS 27" bezel is a bit wide and a bit tall,  what is the best tool for a clean cut on this type of plastic, what have you used and what were the results?
Dagg
whammoed
  • Last login:June 02, 2026, 10:49:42 am
  • Crack don't smoke itself
    • NiceMite
Re: Best tool for cutting Happs Bezel
« Reply #1 on: May 11, 2005, 02:48:27 pm »
Best way is to score it with a utility knife and a straight edge.  Then we you bend it along the line it will break off cleanly.  Same as one of the techniques for cutting plexi but much easier.
dphirschler
  • Last login:February 10, 2021, 10:32:54 am
    • dphirschler homepage
« Reply #2 on: May 11, 2005, 03:50:44 pm »
You can use a table saw (I did), but you better be sure you have a sharp blade or it will chip.  A router may also do well if you can clamp a board to it for a guide.
Darryl
AlanS17
    • AlanS17
« Reply #3 on: May 11, 2005, 03:56:00 pm »
I second the scoring method. Make sure you use a metal straight edge if you can, though. And you might want to mark it in ink or something first. If you score without a guideline you risk moving the straight edge as you score.
"Don't ask me how i know."
Table saws and routers both seem overkill.
BUCKETHEAD
  • Last login:April 04, 2024, 07:31:52 pm
  • Don't hate the player .... Hate the Game
« Reply #4 on: May 11, 2005, 05:02:41 pm »
Try a Dremel tool.
I cut my last marquee with one.
And that was plexi.
AlanS17
    • AlanS17
« Reply #5 on: May 11, 2005, 06:29:34 pm »
I think a utility knife is easier to handle, quicker, and more forgiving.
zip zip zip zip bend bend bend bend done!
teetu
  • Last login:January 17, 2016, 03:29:31 pm
« Reply #6 on: May 12, 2005, 03:06:01 am »
what cutting but did u use on your dremel to cut plexi?
Dagg
« Reply #7 on: May 12, 2005, 01:05:45 pm »
I ended up using a dremel which I originally purchased to do the t-molding slot, and it came out great.
The bit I used is like a mini table saw blade.  I dont think it was included but I picked it up at Depot when I bought the dremel.
Thanks again!
Dagg
itguy
  • Last login:November 10, 2021, 01:27:15 pm
  • Don't take life too seriously, it's not permanent.
« Reply #8 on: May 17, 2005, 11:13:50 am »
I used the utility knife w/ straight edge to cut the bezel slightly larger than what I needed and then used a small planer to trim the edged to an exact fit.
Hoagie_one
  • Um....whats a cabinet
« Reply #9 on: May 17, 2005, 11:22:32 am »
a hatori hanzo sword?
  • Last login:June 10, 2026, 01:52:21 pm
« Reply #10 on: October 09, 2005, 04:21:29 pm »
Any other suggestions?  I'm about to trim my 19" one and I don't want to mess it up.  Also, I have to round the corners of the bezel so it will fit in the cutout for my cocktail table top...  It's pretty thick material...
whammoed
    • NiceMite
« Reply #11 on: October 09, 2005, 07:38:48 pm »
NIVO
« Reply #12 on: October 09, 2005, 07:56:49 pm »
laminate scoring tool and a straight edge will give a clean and exact cut(best on straight cuts)
flyguy1821
  • Last login:October 23, 2022, 11:06:19 pm
« Reply #14 on: October 10, 2005, 09:39:01 pm »
can anyone tell me what the exact inside and outside dimension are for a Happ 27 inch Bezel? Kind of hesitant to buy one until I find out.  Thanks
