June 19, 2026, 12:26:40 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Video Games
through our link. Thank you!
Main
Monitor/Video Forum
WG K7000 Verical Deflection Problem
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: WG K7000 Verical Deflection Problem (Read 3345 times)
Karetaker
Trade Count:
+1
Full Member
Offline
Last login:July 28, 2022, 08:19:40 pm
I want to build my own arcade controls!
on:
May 11, 2005, 12:29:05 pm »
I'm new here so first I'll send a "Hello" out to everybody.
I have a 19" Wells Gardner K7000 that has no vertical deflection. Usually not a big deal. First I checked the pots on the control board and the main chassis board. Both were fine. I checked for
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Last login:October 12, 2021, 12:25:59 am
Technician
Re: WG K7000 Verical Deflection Problem
Reply #1 on:
May 11, 2005, 05:57:36 pm »
Bad solder joints all over the board. Sometimes an open resistor. Check the vertical yoke resistance. Tantalum capacitor C51 is known to go bad. It's value is critical. If it goes way off value (or worse, open) you lose vertical deflection. If it drifts a little bit the picture will not have enough height.
Logged
Karetaker
Trade Count:
+1
Full Member
Offline
Reply #2 on:
May 15, 2005, 05:46:15 pm »
Thanks Ken. I appreciate the input. I've made a note about C51. I tried changing C51 but that wasn't the problem. I did go over all the solders, I just forgot to include that in my original post. I tested the output of IC3 it should have been 12v but I had 24v. Then the voltage reg went out on me. I had to make sure I was working on a K7000 and not a U5000 as it was acting just like one. Reluctantly I changed IC3 AGAIN! I don't know if I got a bad IC from the factory or if it went out after putting it in but it was bad. It's up now but I've got a bad fold on the bottom that I can't adjust out. *sighs*
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Reply #3 on:
May 15, 2005, 06:41:27 pm »
The "50/60 hz" pot adjusts the foldover.
Logged
Karetaker
Trade Count:
+1
Full Member
Offline
Reply #4 on:
May 16, 2005, 11:37:12 am »
Yup, that was the first thing I went for when I was adjusting it. After cranking it all the way to the side that improved it, I still have a terrible foldover. I'm just getting ready to dive back into troubleshooting it now. *sighs deeply*
Thanks Ken
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Reply #5 on:
May 16, 2005, 11:50:19 am »
Has this had a capkit? If not then that could be the problem.
Logged
Karetaker
Trade Count:
+1
Full Member
Offline
Reply #6 on:
May 16, 2005, 12:14:38 pm »
Yes.... a capkit was one of the things I did originally. I'm pretty careful not to miss any. I go over the board and mark the top of them all with a permanent marker so I don't miss any.
Logged
Karetaker
Trade Count:
+1
Full Member
Offline
Reply #7 on:
May 16, 2005, 02:11:42 pm »
I found it Ken..... Thanks so much for your help. I repaired a couple of bad traces-landings, and it fired up.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
