Author Topic: ipac 4 problem  (Read 1130 times)
Thedude1987
  • Last login:May 07, 2005, 09:52:49 pm
ipac 4 problem
« on: May 07, 2005, 08:57:26 pm »
im using an ipaq 4 and most of the buttons work but only when sw6 is held down.  The buttons will not work unless this button is held.  The joysticks work, but not the buttons.  again the buttons only work when this button is pressed.  any ideas why i have to hold down this button in order for the others to work?  im super noob guys
Tiger-Heli
    • Tiger-Heli
Re: ipac 4 problem
« Reply #1 on: May 07, 2005, 09:31:56 pm »
Any chance you have the microswitch connected to SW6 wired to the NC terminal instead of NO - it's USUALLY the middle and end terminals you wire between, but not always.
Double check all your wiring.
