Author Topic: What would cause these problems?  (Read 2106 times)
quadmasta
  • Last login:May 18, 2022, 03:23:00 pm
    • Approximate Arcades
« on: May 06, 2005, 08:31:03 pm »
I bought a converted R-type cabinet and the monitor gives a good picture just has a few issues.  There's a blue layer around the whole perimeter of the screen and there's some horizontal lines across it but only at the top.
AlanS17
    • AlanS17
Re: What would cause these problems?
« Reply #1 on: May 07, 2005, 12:05:07 pm »
If you were going to make me guess I'd say it's magnetic interference. To tell the truth, though, I don't honestly know.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #2 on: May 07, 2005, 02:40:40 pm »
Damaged shadow mask???
Later,
dabone
quadmasta
« Reply #3 on: May 07, 2005, 11:53:28 pm »
I forgot to mention that grid test pattern is from a Neo Geo board.  Someone told me that all Neo boards do that but I'm not sure.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: May 09, 2005, 02:19:09 pm »
Looks to me like the blue is over-driven.
Do you have a test pattern with all colors present on screen at the same time?
NO MORE!!
MonitorGuru
« Reply #5 on: May 09, 2005, 02:55:38 pm »
You're overscanning the vertical on the top causing a fold-over of the test pattern lines making for the extra blue lines appearing stretched out at the top of the screen. Shrink the vertical with the VSIZE control to make it all fit and the extra lines will disapppear.
As far as the strange blue edge... are you sure the test pattern generator isn't doing that?  The only other thing that could possibly cause that is some really wacked up convergence rings AND additional magnetism around the neck or back of the tube that would not be allowing the RED and GREEN guns to deflect to the entire width of the screen.
Either that or the edges of the Red and Green grids are toasted (the grids help propel the electrons to the front of the tube). However that would be very very unlikely.
If this is indeed the problem of the tube and not the pattern being generated, Ken will have to help on this one!
