Author Topic: neo-geo and mamewah  (Read 1198 times)
roast
  • Last login:August 05, 2005, 06:06:37 pm
neo-geo and mamewah
« on: May 06, 2005, 03:00:59 am »
hi there peeps i was wondering if anybody knows a neo-geo emulator that works with mamewah? i have tried neomame and neoragex but with no luck so far. ???
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
Re: neo-geo and mamewah
« Reply #1 on: May 06, 2005, 08:52:05 am »
Mamewah should be able to support any emulator that runs from a command line. Neomame should certainly be no problem. Personally I just run Neogeo stuff on MAME without any trouble.
jcrouse
    • CPViewer
« Reply #2 on: May 06, 2005, 04:20:58 pm »
Check out my website at http://home.comcast.net/~cpviewer . I use Nebula for NeoGeo and NeoGeo CD's. It works great. All the layouts and ini file settings are on the site.
Enjoy,
John
roast
« Reply #3 on: May 09, 2005, 06:22:42 am »
ok thanks guys i will try with your ini file john will let you know if it works  :)
tm
  • Last login:July 14, 2006, 10:04:57 am
« Reply #4 on: May 26, 2005, 06:56:13 am »
i use neomame32, and it works perfect. Try it!
tas
