Author Topic: Help with Happ Universal joystick/ Ultimarc E-Stick  (Read 2164 times)
Timstuff
  • Last login:April 16, 2014, 02:24:29 am
  • I feel asleep !!
« on: May 03, 2005, 11:43:33 am »
My Universal joystick came today, but I'm having some confusion about it, namely switching it to 4-way mode.  I loosened the screws on the bottom of the gear and twisted it into the 4 way position. However, the articulator is still able to press two switches at once, which will register as a diagonal! So what am I supposed to do to keep the articulator from pressing diagonals? Do I need to buy a special 4-way articulator, or am I supposed to do something with the one it came with?
Also, I can't figure out how to unscrew the base from the top! That could be a problem when it's time to install it. Is there a trick to it, or am I just not applying enough force?
« Last Edit: May 03, 2005, 12:07:49 pm by Timstuff »
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
Re: Help with Happ Universal joystick
« Reply #1 on: May 03, 2005, 11:55:03 am »
I just got one the other day and it does the same thing.  I haven't mounted it yet, but I don't think it will actually effect gameplay.  When you're actually playing how long do you think it will actualy be on that spot.  I also don't notice it when I move from up to left.  Only when I tr to hit that spot.
This is also the ulimarc E-Stick if anyone has one actually installed.
Tiger-Heli
    • Tiger-Heli
