Author Topic: Mamewah and Windows Games - Where's my mouse pointer?  (Read 1215 times)
DreamWeb
  • Last login:July 25, 2020, 08:36:59 pm
« on: May 02, 2005, 08:01:39 pm »
Hey guys.
I have Mamewah setup to run .link files for my Windows games.  The problem is... is that when I launch games such as Hamsterball and Gutterball... they play fine.. but I can't see my mouse cursor.  I can see the mouse cursor just fine if I run the games directly from Windows.
I'm sure it's a focus issue of some sort...  Anyone have any suggestions?  I've tried changing the Safelaunch and nodosbox settings with no luck.
d.
Here is part of my .ini
### 0021.ini (mamewah v1.61) ###
emulator_title                            PC Games
### List Generation Settings ###
rom_path                                  c:\systems\pc
rom_extension                             lnk
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       PC
commandline_format                        "[name].[romext]"{nodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]
alt_commandline_format_2                  [name]
« Last Edit: May 02, 2005, 08:38:17 pm by DreamWeb »
quarterstringer
  • Last login:June 19, 2016, 03:35:04 pm
  • Rampart
    • Rampart
Re: Mamewah and Windows Games - Where's my mouse pointer?
« Reply #1 on: May 03, 2005, 01:01:54 am »
I haven't tried it, but maybe changing the show_cursor from 0 to 1 in the mamewah.ini will help.
DreamWeb
« Reply #2 on: May 03, 2005, 01:30:08 am »
Hey!  A good idea.
But, that didn't work.  I mean.. yes, it showed the cursor in the Mamewah menus.. but, even with that.. the cursor didn't show up in my Windows Games (unless I was hilighting an actual menu selection inside the game).  Hamsterball and Gutterball for example.
d.
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #3 on: May 03, 2005, 08:53:33 am »
Add the {cursor} flag to your commandline_format.
-sab
DreamWeb
« Reply #4 on: May 03, 2005, 07:10:49 pm »
Thank you!!  That did the trick!
d.
