Author Topic: Metal "Pump" style dance pad  (Read 12875 times)
paigeoliver
  • Awesome face!
« on: May 02, 2005, 01:19:21 am »
Has anyone ever made, found, or can make a metal "Pump it Up" style Dance Pad.
The Pump it up layout is exactly reverse of the common DDR layout. It has 5 buttons, center and all 4-corners.
Matter of fact, I would be willing to trade a nice dedicated classic and extras for dual Metal Pump style pads (must be good quality).
kenzo42
  • Last login:November 23, 2024, 01:11:32 pm
Re: Metal "Pump" style dance pad
« Reply #1 on: May 02, 2005, 03:11:24 am »
i've made a metal ddr pad, from ddrfreak's website. it was pretty easy to make. the instructions are also pretty detailed. i can't imagine a pump it up pad would be much different.
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #2 on: May 02, 2005, 09:45:47 am »
I know I've seen one, but I have no idea of the link.
But Kenzo is right... the basic DDR pad plans that are floating around the net will work fine with PIU.  You have to cover those squares anyway, so it's just a matter of swapping button panels and blank panels.  The rest of the plans will be identical.
first off your and idiot
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: May 02, 2005, 10:03:00 am »
or make a 9 panel pad to do both PIU and DDR :)
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
« Reply #4 on: May 02, 2005, 12:31:40 pm »
Now thats some sound thinking there!
pointdablame
« Reply #5 on: May 02, 2005, 01:26:27 pm »
that's actually exactly what I seem to remember seeing a while back, but for the life of me, I can't find it again.  You'd just have to be sure that the "other" buttons for the respective games wouldn't screw with your controls obviously.
ErikRuud
  • Last login:March 23, 2026, 07:42:27 pm
« Reply #6 on: May 02, 2005, 01:57:52 pm »
A nine button (Actully 11 buttons including start and select) is what I plan on doing.  My nieces & nephews play DDR on their Playstation so I want to have pads for Stepmania on my cabinet.
I am most likely going build a hybrid of these to pads, and connect it through my IPAC.
http://webpages.charter.net/jamjohn/ddrhow.htm
http://home.comcast.net/~stoli16/ddr/index.html
American Laser Games Wrapper
O2em Rom Utility
SirPoonga
  • Puck'em Up
« Reply #7 on: May 02, 2005, 02:24:50 pm »
I have a softpad with 8 directions,  I wish it had the middle button for PIU :(
Timstuff
  • Last login:April 16, 2014, 02:24:29 am
  • I feel asleep !!
« Reply #8 on: May 02, 2005, 03:08:21 pm »
If you're a BYO type of guy, this guy's project looks like it could work it you were to modify it.
http://www.digitaltorque.com/mydancepad/
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
« Reply #9 on: May 02, 2005, 03:25:20 pm »
btw, they are getting CHEAP on ebay.  less then 100 shipped on a daily basis.  They used to be MUCH more expensive.
I might consider buying one for my daughters!
SirPoonga
  • Puck'em Up
« Reply #10 on: May 02, 2005, 03:30:40 pm »
Yes, I've noticed that too. $60 before shipping.  They use to be $150 before shipping a year or two ago.
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
« Reply #11 on: May 02, 2005, 04:12:34 pm »
Dancing game geek accuracy note:
The corner arrows on a PIU pad are 11"x13", which means that you cannot have an arcade accurate 9 panel pad for both PIU and DDR.
If no one feeds the trolls, we're just going to keep eating your goats.
SirPoonga
  • Puck'em Up
« Reply #12 on: May 02, 2005, 04:27:44 pm »
Actually, you can but it would look goofy :)
paigeoliver
  • Awesome face!
« Reply #13 on: May 02, 2005, 05:34:08 pm »
You can't have one anyway, I don't know about DDR, but in Pump the feel of the raised metal blank areas is one thing that helps keep me on track and not having to look down at the pad. A 9 panel pad would just be ALL panel with no reference points.
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #14 on: May 02, 2005, 05:46:25 pm »
  What if you design your pad with those squares raised?
  What size are the squares on DDR?
-sab
paigeoliver
  • Awesome face!
« Reply #15 on: May 03, 2005, 02:55:39 am »
Boo Yah! Found one.
There is a high end metal pad called "Cobalt Flux", and the sucker has the middle button.
Now I am gonna have to move (I live on the second floor).
Either I will have to move, or build a Pump setup in the common basement. No way could I get away with having it in the apartment, even if I got switched to a first floor unit I would still shake the whole building.
« Last Edit: May 03, 2005, 03:08:08 am by paigeoliver »
abrannan
« Reply #16 on: May 03, 2005, 12:38:51 pm »
-sab
11"x11"
pointdablame
« Reply #17 on: May 03, 2005, 12:47:45 pm »
Boo Yah! Found one.
I wish I could afford a CobaltFlux, they are the best dance pads on the market short of an actual machine.
If I had known you were willing to buy a premade one, I'd have recommended it, but I thought you were looking for a new project heh :)
« Last Edit: May 03, 2005, 12:49:47 pm by pointdablame »
