Author Topic: Mamewah first game issue  (Read 1387 times)
Quarters
  • Last login:July 08, 2010, 06:53:17 pm
  • I am not now, nor have I ever been, a llama!
    • Quarters Arcade Site
« on: May 01, 2005, 04:25:02 pm »
After mamewah starts very often the first game I attempt to launch hangs. An hour glass appears then nothing. If I use taskmanager to end task on mame then all works well. Obviously in a cab this is undesirable. has anyone else seen this behavior, found a way to fix it?
Thanks,
Quarters
97.4 percent of all statistics are full of crap.
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
Re: Mamewah first game issue
« Reply #1 on: May 01, 2005, 04:38:43 pm »
Just a hunch, but are you running MAME32?
Quarters
« Reply #2 on: May 01, 2005, 05:53:47 pm »
Nope. Using plain old mame ver 0.89.
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #3 on: May 01, 2005, 05:56:49 pm »
What do you mean "it hangs"? Does the screen freeze? Do you just get nothing on the screen?
  I wonder if this is a window-focus issue.  Try searching the software forum for "windows focus" and see if any of those solutions work for you.
-sab
Quarters
« Reply #4 on: May 01, 2005, 10:14:05 pm »
By hangs I mean I see the screen saying loading 'cool game x', hour glass symbol cursor appears, cursor still moves with mouse or trackball but the game does not load. windows task manager shows both mamwah and mame to be "not responding. If I end task on mame then relaunch the game or any other game it works fine. only the first game that I launch sometimes gives me this problem. Interestingly if I shut down mamwah and restart it the problem does not reoccur. It seems to only happen the first time starting mamewah after a reboot.
