Author Topic: Daphne  (Read 2616 times)
psychlone78
  • Last login:October 23, 2005, 11:03:55 pm
  • Shut up foo!!!
Daphne
« on: May 01, 2005, 11:14:45 am »
Hello All,
I have Dragon's Lair 1 & 2, and Space Ace. Is there anyone out there that can give me some instructions on how to get them to work in daphne(emulator). I really need help with this problem. I spent nearly 90 bucks for these disks and have yet to play them. The original way to get them to work by downloading windvd just isnt working. :(
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
Re: Daphne
« Reply #1 on: May 01, 2005, 12:23:00 pm »
What versions do you have?  You need to convert the video / audio files to ones that dalphe can read.  There is a program to do this (dvdtodalphe??)... But it only works on the DVDRom version, not the DVD / ps2 / xbox version whatever its called.
Rod1968
  • Last login:February 03, 2007, 10:19:45 pm
Re: Daphne
« Reply #2 on: May 01, 2005, 12:31:21 pm »
psychlone78
  • Shut up foo!!!
Re: Daphne
« Reply #3 on: May 01, 2005, 01:35:53 pm »
I have the DVD-ROM versions. I tried the DVD2Daph but I cant get daphne to load right. It will say missing bin files or something. Now I cant even get the daphne  loader to run. It says runtime error
psychlone78
  • Shut up foo!!!
Re: Daphne
« Reply #4 on: May 01, 2005, 03:34:25 pm »
--DAPHNE version 0.99.6
--Command line is: C:\Daphne\daphne.exe ace vldp -framefile C:\Daphne\framefile.txt -fullscreen -nohwaccel -nocrc
--CPU : GenuineIntel 2200 MHz || Mem : 256 megs
--OS : Windows XP/.NET || Video : Intel(R) 82845G/GL/GE/PE/GV Graphics Controller
LDV1000 : Instantaneous seeking enabled!
Disabling ROM CRC check...
Set 640x480 at 32 bpp with flags: 80000000
Initializing sound system ...
No joysticks detected
Loading roms/ace/sa_a3_u1.bin ... 0 bytes read into memory
ROM image file sa_a3_u1.bin could not be loaded
Could not load ROM images! You must supply these.
Shutting down sound system...
Shutting down video display...
daveg2000
  • Last login:January 02, 2009, 08:55:51 pm
  • PSP? Yeah right. GP2X Baby! This thing is awesome
    • www.davegrams.com
Re: Daphne
« Reply #5 on: May 01, 2005, 03:47:31 pm »
looks like you dont have your rom files in the right location.
(Plus.. make sure in the Daphne settings, to tell it you
are using MPEG video instead of a laserdisc player - there
is a dropdown somewhere in there)
I cant remember Exactly, but I think I had to unzip roms in
the directory instead of leaving them in a .zip format....
...so I will ask you... "Deal, or No Deal?"
psychlone78
  • Shut up foo!!!
Re: Daphne
« Reply #6 on: May 01, 2005, 05:04:59 pm »
Where can I put the rom files. Are those what I downloaded or what I took from the DVD-Roms?
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
Re: Daphne
« Reply #7 on: May 01, 2005, 05:30:51 pm »
The roms are what you downloaded.  Inside the rom directory are folders for each game.  Inside the game folders is a TXT file that tells you which files it will be looking for.  You will have to unzip what you downloaded and make sure the files match...
