Author Topic: Ball-top joystick needed for CP  (Read 1820 times)
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« on: April 29, 2005, 06:19:07 pm »
I'm thinking about making the CP for my bartop made for vintage games, but I'm a bit lost. There are so many ball-top joysticks, which one is what I want?
I need something that can mount under a 1/8" plate. I want it to be fairly high above the panel, no hitting your knuckles on the panel joys.
I also think I am going to go with a 4-way, or is that too limiting? I want to be able to play most vintage games. I am also going to be going with 3 buttons (I think I heard only a few old games used 4 buttons).
Price is also a factor (one of the bigger ones). I would go with a T-Stik Plus with a ball-top, but that would cost too much. Also, The T-Stik has shorter throw than what I want for this CP.
Thanks for the help!
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
Goz
  • KOTA
Re: Ball-top joystick needed for CP
« Reply #1 on: April 29, 2005, 07:02:36 pm »
How about a HAPP super in 4 way mode with a Groovy Game Gear Versa Ball. It puts the ball up a good distance from the CP.
-Goz
Tahnok
    • Table Arcades
« Reply #2 on: April 29, 2005, 08:34:07 pm »
-Goz
Looks promising, but where do you get the ball-top for it? It looks like you can only get it with the default bat handle. Can the mode be changed easily by just going under the CP?
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #3 on: April 30, 2005, 12:34:32 am »
groovygamegear
They also come in chrome.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #4 on: April 30, 2005, 08:39:56 pm »
Don't buy a Super if you want a 4-way.. buy a Ms. Pac/Galaga Reunion stick.  It's the same stick, but with true 4-way action.  The GGG handles should fit it, as well.
Or, if you don't want/need the fancy GGG handles, and want to save some $$, buy one of these:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=13718&item=6172649240&rd=1
It's the Ms. Pac/Galaga Reunion stick base again, but with a red ball handle.
Tahnok
    • Table Arcades
« Reply #5 on: May 01, 2005, 03:13:27 am »
Can you change the Happ Supers fairly easily? If I put a hinge on my CP, could it be 4 and 8 way changeable (no need to use tools)?
Looks like I will probably get a super if they can be changed and a reunion if it can't.
While on the subject of my CP, is 3 buttons enough? Are there even any 4-way games that use more than 3?
Goz
  • KOTA
« Reply #6 on: May 01, 2005, 03:27:12 am »
No, you will likely need a screwdriver to get the e-clip off and possibly some needle nose pliers to get the e-clip back on after making the actuator change.
