Author Topic: HELP! Windows Explorers crashes with my screen shots  (Read 2112 times)
jcroach
  • Last login:March 31, 2026, 12:26:11 pm
« on: April 29, 2005, 09:25:17 am »
Help!
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re: HELP! Windows Explorers crashes with my screen shots
« Reply #1 on: April 29, 2005, 09:42:22 am »
Try these steps:
1) Go to Tools -> Folder Options
2) Click the View tab
3) Check Show hidden files and folders
4) Click OK.
5) Start a search by going to Start -> Search -> For Files or Folders.
6) In the Search for files or folders named enter thumbs.db.
7) In the Look in field, enter the directory with all your screenshots
8) Click Search now.
9) Delete all results.
10) Try opening the folder again.
-sab
jcroach
« Reply #2 on: April 29, 2005, 09:45:52 am »
Try these steps:
4) Click OK.
-sab
Thanks!  I'll try this tonight.  Would I need to do this everytime I want to use that folder, or just once?  Will photoshop make another tumbs.db file at any time in the future?  How do I keep this from happening again?
screaming
  • Registered lUser
« Reply #3 on: April 29, 2005, 10:37:18 am »
  I'm not exactly sure yet if this will fix your problem - I'm just guessing.
  When you view a folder in Windows XP With the "View mode" set to "Thumbnail", Windows will automatically create a hidden file in that folder called "thumbs.db" to cache all the images, presumably to speed up viewing the thumbnails the next time you enter the folder. I'm guessing that this file is corrupt somehow, causing Windows to throw a fit.
  Windows created it, not Photoshop.  If this does fix your problem, you can turn off thumbnail caching by going to the same screen in the Folder Options dialog and check Do not cache thumbnails.  After you do this you'll probably want to click Like Current Folder above to set the option for every folder on your hard drive, and then repeat the same search outlined above for your entire hard drive(s) to get rid of all your thumbs.db caches.
  Good luck, and post back if it works!
-sab
jcroach
« Reply #4 on: April 29, 2005, 03:39:58 pm »
I found some info on this on the web finally.
« Last Edit: May 02, 2005, 09:05:37 am by jcroach »
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
« Reply #5 on: April 29, 2005, 06:53:17 pm »
As others have stated, it's a bad thumbnail.db. I've run into this problem a number times and deleting the thumbnail.db in the offending directory fixes it every time.
Brad
daywane
  • Last login:September 01, 2026, 05:00:16 am
  • GRRRR!
« Reply #6 on: April 30, 2005, 09:00:50 am »
never knew what that thumbnail.db was.
thanks
jcroach
« Reply #7 on: May 02, 2005, 09:05:22 am »
It seem like it's a conflict between the way Photoshop handles files and the way Windows Explorer handles thumbnails.
