Author Topic: WG9200/reverse kvm/ArcadeVGA question  (Read 1573 times)
Buschmaster
  • Last login:January 21, 2007, 06:57:09 pm
  • Trying to finish my first cabinet. Almost there!
« on: April 27, 2005, 11:51:18 am »
I have a WG9200 42a, ArcadeVGA video card and a Belkin Reverse KVM.
The reason I have the reverse KVM is because I don't have the cash to have a dedicated machine for the arcade cabinet and that I can use the computer away from the cabinet.
Is there any reason that anyone can think of that I shouldn't be using a reverse KVM?  Under the ATI control panel I am unable to select Television.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: WG9200/reverse kvm/ArcadeVGA question
« Reply #1 on: April 27, 2005, 03:07:22 pm »
I don't see any reason why this should not work. In fact do you need to switch the video? You might be able to leave the TV and the monitor connected. A KVM does not normally switch TV signals, only VGA anyway.
Andy
Buschmaster
« Reply #2 on: April 27, 2005, 03:23:47 pm »
Having a PC monitor and WG9200 hooked to the KVM seems to work fine, but I wasn't sure if I wasn't getting what I should out of the ArcadeVGA card by doing this.
I was sure to buy a better VGA cable then then one that came with the monitor.  If anyone buys one make sure you buy a nice VGA cable you will notice a difference.
