Author Topic: I am looking for Ideal Settings for Project64 in cab  (Read 2913 times)
vartech
  • Last login:March 20, 2013, 03:38:17 pm
  • The Great Swordsman Hiko
« on: April 25, 2005, 09:10:16 pm »
I have a cab using a 3400 athlon xp, Windows XP Pro, mamewah, command line mame, arcadeVGA card and a WG monitor.  what are the best settings to get the best image and fews problems with Project 64?
JCKnife
  • Last login:November 04, 2008, 09:41:57 pm
Re: I am looking for Ideal Settings for Project64 in cab
« Reply #1 on: April 26, 2005, 12:25:50 am »
There's really not much to it...fullscreen, 640x480...use jcrouse's wrapper if you're using mamewah...
vartech
« Reply #2 on: April 26, 2005, 10:05:05 am »
Thanks, but I am looking for the best settings for graphic settings such as which boxes to check and which not to.  example in Zelda the words are not there I played around with the graphic settings and now the show but I would like to know which should be checked and which should not.
JCKnife
« Reply #3 on: April 26, 2005, 11:52:38 am »
Except for a custom resolution for Yoshi's world, I'm running all graphics settings default.
If a game has skippy sound, I pull up the audio menu and check the box that says "synch emulation to audio" or something like that. Otherwise, I'm running it pretty much "out of the box" and have a very similar setup, sounds like.
vartech
« Reply #4 on: April 26, 2005, 12:35:03 pm »
are you running pj64 1.6 or 1.5?  I noticed my problems with 1.6 as far as graphics and errors.  1.5 worked better for me so I thought it must be a settings in the graphics tab because once I made a few selections it ran better.  I just wanted to make sure I did it correctly ;D
JCKnife
« Reply #5 on: April 26, 2005, 01:41:45 pm »
I'm using 1.6. I never tried 1.5.
