Author Topic: Daisy chaning  (Read 5109 times)
RTSDaddy2
  • Last login:April 03, 2014, 08:28:03 pm
  • Bees! Oh bother!
Daisy chaning
« on: April 25, 2005, 08:44:45 pm »
Hey guys -
Maybe it was because it was early this morning when I read it, but something about this didn't make sense.
In daisy chaining the grounds together, is it one wire running from the IPAC ground to the grounds on both joysticks and buttons, or do you have two seperate wires?
I'm not sure I asked that question well, but maybe someone will understand what I meant! :)
RTSDaddy2
Red5
  • Last login:October 05, 2006, 02:32:12 pm
Re: Daisy chaning
« Reply #1 on: April 26, 2005, 07:45:26 am »
I assume you're talking about daisy chaining the ground from the iPac to 1 Joystick and N-Buttons... Yes it's fine to use just one ground, that's what I did on my setup.
I ran the ground from the iPac Player 1 GND to the joystick and then from the joystick to the buttons, works a treat. The only exception was for the Player 2 button which I wired to the Player 2 GND, however I'm not sure even that was necessary?
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:Today at 12:16:25 pm
Re: Daisy chaning
« Reply #2 on: April 26, 2005, 08:52:58 am »
Wire your ground from one ground on the I-PAC, daisychaining to all the COM leads on your microswitches, ending with the chain on a second ground on the I-PAC. If there's a single break anywhere in your daisychain, all your buttons will still work because each will have a path back to ground.
You don't *need* to connect up to the second ground on the I-PAC, but it does give you a measure of redundancy.
---- saint
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
RTSDaddy2
  • Bees! Oh bother!
Re: Daisy chaning
« Reply #3 on: April 27, 2005, 10:40:35 pm »
Thanks! I sort of saw it as being one wire that ran from the IPAC ground, through ALL the switches, and back to the ground at one point, but then like I said - and I don't recall what it was even today - something made me wonder if I'd read that wrong.
Thanks again y'all!
RTSDaddy2
« Last Edit: July 06, 2006, 03:52:25 am by RTSDaddy2 »
