Author Topic: Fixing a marquee  (Read 1202 times)
Voodooray
  • Last login:July 24, 2006, 04:52:41 am
  • Load ya swine!!!!!
Fixing a marquee
« on: April 24, 2005, 01:19:43 pm »
Hi everyone. :)
It's probably very obvious, but i'm building my first cab and i can't figure out how to fix the marquee in place.
Thanks in advance for any help.
Voodoo Ray.
88 Acid Revival, Safe!
Voodoo Ray.
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
Re: Fixing a marquee
« Reply #1 on: April 24, 2005, 02:15:29 pm »
Most people use marquee holders that are used on real arcade machines. You can get them from Happs and other places too.
I didn't use them on my cab I made a wood frame that is hinged at the top and has magents at the bottom to hold it closed but marrquee holders are just find for most cab.
Gary
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
« Reply #2 on: April 24, 2005, 05:36:02 pm »
If you order the marquee holders, get them from ponyboy, save yourself that $25 minimum you need to spend at Happs and getting screwed with shipping.
http://forum.arcadecontrols.com/index.php/topic,31449.msg266836.html
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
« Reply #3 on: April 24, 2005, 08:50:36 pm »
Also search for some posts about using aluminum drop-ceiling supports. They are about 1.25" wide (guess), "L" shaped, and sell for like $4 in 10 or 12-foot lengths at Home Depot. Hack-saw and black paint and you are in business. Several people here have had success this way.
I just spent some time in an arcade looking at marquee brackets on different machines and several used similar arrangements (often times with a Happs bracket on the top and an aluminum "L" on the bottom).
My marquee lexan is recessed by 1" and currently held in by friction. I'm still brainstorming on a permanent home-brew solution but intend to try a variant of the "L" brackets I just mentioned.
- pmc
stevodevo
  • Last login:March 07, 2022, 11:27:18 am
« Reply #4 on: April 25, 2005, 11:12:42 am »
never thought of the aluminium - i'm using the same method but it's that plastic l-shaped corner protector material.  you can buy a pretty long section at lowes or wherever for about $2. the kind i bought was clear but i painted it black and then just screwed it into the top and bottom of the marquee area on my cab. works great and changing marquees is a snap!
