Author Topic: KEYWIZ USB big mistake or not? Need Help  (Read 1302 times)
vartech
  • Last login:March 20, 2013, 03:38:17 pm
  • The Great Swordsman Hiko
« on: April 23, 2005, 11:42:09 am »
I purchased a Key-Wiz usb interface I thought it emulated a keyboard not a gamepad.  I want to use it in a cab using Mamewah as my front end and command line mame.  I am runnning windows xp pro.  Is there a way to make the gamepad at like a keyboard?  I need it to be a automatic process that would load when the PC starts.   Please help I am in the last steps and want to finish this ASAP. ;D
Thanks inadvance
Hoagie_one
  • Um....whats a cabinet
Re: KEYWIZ USB big mistake or not? Need Help
« Reply #1 on: April 23, 2005, 11:43:50 am »
I dont see the problem really.  Mame can use joypads as can all the major emulators.
vartech
« Reply #2 on: April 23, 2005, 11:51:27 am »
how about using it for mamewah?  you see I need to control my cab by the control panel only.  I do not want to use a keyboard.  Is it posible to program it for mamewah?
RandyT
  • Last login:May 04, 2026, 05:18:46 pm
    • GroovyGameGear.com
« Reply #3 on: April 23, 2005, 11:57:18 am »
Clarifications first:
There is no KeyWiz USB, you have a GP-Wiz, which is a GamePad/Joystick based USB interface.
But no need to fret.
JoytoKeyworks very well, and failing that, RBJoy v7.
Both will let you assign gamepad button presses to keys and will work fine for controlling front ends.
Just email me if you need copies of them, they are free.
RandyT
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
« Reply #4 on: April 23, 2005, 01:31:21 pm »
No need to use JoytoKey just for Mamewah.  Mamewah accepts joypad inputs.  All the info you need on how to configure the controller config file should be in the documentation that comes with mamewah.
