Author Topic: Need help remapping Lunar Lander throttle!  (Read 1638 times)
AllisterFiend
  • Last login:June 04, 2013, 05:04:16 am
  • Rush 2112
    • Check out my Dragon's Lair/MAME cabinet.
« on: April 20, 2005, 07:08:50 pm »
I seem to be having trouble mapping the throttle in Lunar Lander to a different key.
All I want to do in MAME .95 is change the PADDLE DEC from the UP ARROW to the RIGHT CTRL but after I do it I have no control over the thrust.  Can this be done?, I noticed that the UP ARROW is highlighted in white (what does that mean?).
Any help would be appreciated.
Allister Fiend
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re: Need help remapping Lunar Lander throttle!
« Reply #1 on: April 21, 2005, 07:50:12 am »
Lunar Lander used a throttle lever which is difficult to emulate with simple buttons. Even with the standard key-mappings, I just tried Lunar Lander and it's very un-responsive to thrust. I think this is because the 'maximum' throttle is set too low.
Try going into Analog Controls > Paddle Digital Speed and set it to 20 or 25 or whatever feels good to you.
AllisterFiend
  • Rush 2112
« Reply #2 on: April 22, 2005, 07:09:13 am »
Thanks JoyMonkey, that seemed to do it, I did not think I needed to go there and change anything since I just wanted to change the key that activated the thrust.  Once again, thanks for your help.
Allister Fiend
