Author Topic: Rotary adapter for Happ/Midway 49-way Joystick  (Read 28588 times)
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Rotary adapter for Happ/Midway 49-way Joystick
« Reply #120 on: June 29, 2005, 12:12:32 am »
Kremmit - the main problem I see is that when you move the joystick, you are probably going to bind up those gears, I think, maybe not.  I can probably be done, but not easily.
Why would they bind up?  They're just floating in space, after all!   :P
Seriously, that pic isn't meant to be the actual mechanism, just a visual explanation of the concept.
To actually build it, you'd need the switch and it's gear to attach to a bracket that is in turn attached to the shaft itself.  That way, the gears will move with the shaft and not bind up.  Same bracket should also hold the leaf (or micro) switch on the bottom for the top-fire.  And of course, then you'll need that bracket hooked into an anti-spin rig similar to the ones in fl0yd's rotary kit.
I can see this magic bracket in my head, but it's more then I felt I could tackle in Photoshop.
