Author Topic: ddraw set to 1 does not load game????  (Read 1311 times)
vartech
  • Last login:March 20, 2013, 03:38:17 pm
  • The Great Swordsman Hiko
« on: April 18, 2005, 11:14:36 am »
I am running a optiplex 733 with 256ram windows xp, and a ati Rage128 everything loads fine but when I select 1 in my mame Ini file for ddraw needed for stretching the image to full screen the game does not load.
using mamewah and commandline mame95
Lilwolf
  • Last login:May 08, 2026, 06:33:59 pm
Re: ddraw set to 1 does not load game????
« Reply #1 on: April 18, 2005, 12:38:59 pm »
It could be a few things.
first, remove the d3d and use hwstretching to 1.  This SHOULD attempt to stretch to the same resolution.
If this doesn't work.  Then its probably the resolution your monitor doesn't like (MAME is trying to stretch 320x200 -> 640x400 because of exact stretching.... But your monitor can't handle it.... Or whatever)...  Try forcing a resolution you KNOW will work (640x480, 800x600, ect) and try again...
or
use hwstretching.  Some video cards do MUCH better with it (based on opengl instead of d3d)
vartech
« Reply #2 on: April 18, 2005, 12:54:42 pm »
this is my mame.ini file the monitor is set at 800x600 but I am using pivot pro to make it vertical.  using a ati rage128, optiplex gx110 , windows xp pro and mamewah as my FE
### mame.ini ###
### Frontend Related ###
clones                  1
### Windows path and directory options ###
rompath                 roms
samplepath              samples
# inipath               <NULL> (not set)
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
hiscore_directory       hi
state_directory         sta
artwork_directory       artwork
snapshot_directory      snap
diff_directory          diff
ctrlr_directory         ctrlr
cheat_file              cheat.dat
history_file            history.dat
mameinfo_file           mameinfo.dat
### Windows video options ###
autoframeskip           1
frameskip               0
waitvsync               0
triplebuffer            1
window                  0
ddraw                   0
direct3d                0
hwstretch               1
# screen                <NULL> (not set)
cleanstretch            auto
resolution              auto
refresh                 0
scanlines               0
switchres               0
switchbpp               0
maximize                1
keepaspect              0
matchrefresh            0
syncrefresh             0
throttle                1
full_screen_brightness   0.000000
frames_to_run           0
effect                  none
screen_aspect           4:3
### Windows Direct3D 2D video options ###
zoom                    2
d3dtexmanage            1
d3dfilter               1
d3dfeedback             0
d3dscan                 100
d3deffectrotate         1
d3dprescale             auto
d3deffect               sharp
# d3dcustom             <NULL> (not set)
# d3dexpert             <NULL> (not set)
### Windows misc options ###
sleep                   1
rdtsc                   0
high_priority           1
### Windows sound options ###
audio_latency           1
# wavwrite              <NULL> (not set)
### Input device options ###
mouse                   0
joystick                0
lightgun                0
dual_lightgun           0
offscreen_reload        0
steadykey               0
keyboard_leds           1
led_mode                ps/2
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
paddle_device           keyboard
adstick_device          keyboard
pedal_device            keyboard
dial_device             keyboard
trackball_device        keyboard
lightgun_device         keyboard
digital                 none
### Mame CORE video options ###
norotate                0
ror                     1
rol                     0
autoror                 0
autorol                 1
flipx                   0
flipy                   0
debug_resolution        auto
gamma                   1.000000
brightness              1.000000
pause_brightness        0.650000
### Mame CORE vector game options ###
antialias               1
translucency            1
beam                    1.000000
flicker                 0.000000
intensity               1.500000
### Mame CORE sound options ###
samplerate              44100
samples                 1
resamplefilter          1
sound                   1
volume                  0
### Mame CORE misc options ###
artwork                 0
use_backdrops           0
use_overlays            0
use_bezels              0
artwork_crop            0
artwork_resolution      0
cheat                   0
debug                   0
# playback              <NULL> (not set)
# record                <NULL> (not set)
log                     0
maxlogsize              10000
oslog                   0
skip_disclaimer         1
skip_gameinfo           1
skip_validitychecks     1
crconly                 0
bios                    default
# state                 <NULL> (not set)
### Configuration options ###
readconfig              1
verbose                 0
