Author Topic: pc amp sound quality  (Read 2157 times)
kenzo42
  • Last login:November 23, 2024, 01:11:32 pm
« on: April 18, 2005, 02:06:59 am »
is there a quality difference b/t pc speaker amps and an amp used for stereos, like the radio shack sa-155? thanks.
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
Re: pc amp sound quality
« Reply #1 on: April 18, 2005, 12:11:00 pm »
Very much so. A good hifi amp will give you much more detailed sound. Don't forget though that speakers are equally important. Which one you should buy of course depends on your budget. Since you're talking about Radio Shack I can only assume it's tight. The route I took is to use an old mid sized stereo from Aiwa and I'm much happier with it than I was with amplified PC speakers. You should be able to pick one up fairly cheaply.
