Author Topic: Help installing Oscar V2 push spinner  (Read 1045 times)
rgecko
  • Last login:August 18, 2025, 11:02:57 pm
  • makin' da 'cade
« on: April 17, 2005, 04:54:31 pm »
Ok so I have the spinner and my CP is 5/8
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
Re: Help installing Oscar V2 push spinner
« Reply #1 on: April 17, 2005, 05:04:37 pm »
I don't have a V2, but do have some of Oscar's other spinners.  Based on how the shaft is installed in yours is there an extra groove in the shaft coming out the bottom of the spinner?  If so, you may pull the metal keepers and raise the shaft.  The weight and encoder wheel may have set screws to loosen and adjust too.
rgecko
  • makin' da 'cade
« Reply #2 on: April 17, 2005, 06:49:59 pm »
figured it out. seems that you need to take off the little black ring on the bottom, as there is a lock there that holds the shaft in place... all seems good now.  thanks!
