Author Topic: Visualboy advance sdl (modified gui) and MAMEWAH - They wont work together :(  (Read 1624 times)
D5A1AC
Hi all, I'vejust spent the lat few hours searching this forum and google as to how I can get Visualboy advance sdl (modified GUI) working on mamewah. I'm talking about the visualboy from screenshotarchive.com. I am having a lot of trouble with this. I can get MAMEWAH to load up the roms, but when I try to execute one, it just says that its loading for a sec and then goes back to the MAMEWAH menu......? If I type visualboyadvancesdl sims (for example) into cmd, it will run fine, but it just wont work in MAMEWAH. This brought me to the conclusion that maybe MAMEWAH is sending the command line thing in the wrong format.....
If this is true, how can I set it so that it will execute in the format: visualboyadvancesdl rom ?
If I am completely WRONG, can anyone offer some advice as to how I can get the modified sdl visualboy working with MAMEWAH? I'm really stuck here and I need some help from you all  ???
Your help is appreciated
From Mike
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
JCrouse's site has all sorts of mamewah INI files including this emulator:
http://home.comcast.net/~cpviewer
« Last Edit: April 16, 2005, 04:25:00 pm by sc1103 »
JCKnife
  • Last login:November 04, 2008, 09:41:57 pm
Have you tried changing dosbox / nodosbox and safemode/nosafemode?
D5A1AC
Thanks :) I finally got it working.
