Author Topic: naki vga box - DC  (Read 2267 times)
kenzo42
  • Last login:November 23, 2024, 01:11:32 pm
naki vga box - DC
« on: April 13, 2005, 04:54:05 am »
anyone ever have problems hacking this, so it displays at 15khz? all i'm getting is a black screen w/ scanlines that lights up. thanks.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re: naki vga box - DC
« Reply #1 on: April 13, 2005, 11:41:49 am »
It should work (provided you cut the correct wire).  One ground is also sufficient.  Did you use a multimeter to trace pin #6?  or just count from one side over and cut the 6th wire?
Also sent you PM.
kenzo42
« Reply #2 on: April 13, 2005, 02:43:33 pm »
hey dave, i did use the multimeter but it was not in order. it was the 7th one over. when i did the continuity test, both 6 and 7 were giving me a reading. so i cut one, and tested the wire but it was wrong. spliced it back and did the other. i'll try switching it to tv mode instead, in case it was mislabelled. thanks
Dave_K.
    • Arcade Fever
« Reply #3 on: April 13, 2005, 03:23:23 pm »
Checking on a PC monitor will let you know if you cut the correct wire or not (it shouldn't work with a pc monitor anymore).  Yeah both 7 and 6 will read the same on a multimeter because they are both connected to ground.  ;D  So in affect, you are removing pin 6 from ground when you cut it.
