Author Topic: interfacing perfect 360 joysticks  (Read 3361 times)
mattv
  • Last login:June 10, 2022, 06:33:25 am
« on: November 20, 2002, 02:24:19 am »
I know this question has been discussed before, at length, but I can't find any refrence to it and the board search engine turns up nothing.
So.
Is there any way to interface a perfect 360 joystick to your PC?
As far as I can see they run on five volts, which isn't a good start, so i'm guessing that you need some kind of special encoder.
What about a Jpac? I'm using one of those with my (non-perfect) controls at the moment and it works great. Can I simply plug the perfect 360 into that or will it destroy something
Any input appreciated, or a link to the old discussion would be great.
Matt
mattv
Re:interfacing perfect 360 joysticks
« Reply #1 on: November 21, 2002, 03:00:41 am »
Here we go. I knew I had seen this somewhere before
http://www.arcadecontrols.com/arcade_controls.shtml#Joysticks
which links to
here
http://www.mameworld.net/pc2jamma/pc_arc5.html
and here
Next time i need to know this, there will be a refrence to it on the messageboards
