Author Topic: Illustrator export problem  (Read 1779 times)
glDaher
  • Last login:April 15, 2005, 08:02:58 am
« on: April 12, 2005, 07:26:53 am »
Hello all,
I have a little question. A friend of mine used illustrator to make up a package design. I'm not sure what in hell he's got in it.. .all I know is that whenever I try to export the image file to jpeg or psd format, only a portion of the image is exported. actually the front page of the package...
He's got some vector logo if that matters...
any idea?
zorg
Re: Illustrator export problem
« Reply #1 on: April 12, 2005, 09:29:19 am »
is drawing is larger than the "work space" (dunno the english illustrator menu term)
select all the drawing.
check the dimension (transformation window)
copy everything
create a new document with the good size.
paste everything in the new doc.
export should be fine
I'm on the planning stage
glDaher
« Reply #2 on: April 12, 2005, 11:59:38 am »
great, got it, thanks a million..  ;D
