Author Topic: Too much red.. Way too much!  (Read 1029 times)
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« on: April 11, 2005, 10:59:28 pm »
I have another problem with my POW cab. I fixed the no blue problem. It ended up being a loose cable. Now this problem didn't start until I was just letting the game run in attract mode. The whole screen began having a bright red hue to it with red lines the stretch horizontally through the screen. I can still see the game running, but there is now there is lots of red. Adjusting the pots on the back of the monitor have no effect. Do I have a bad solder joint or cap??
I haven't installed a cap kit on it yet. It is a WG 19K7607.
Ken Layton
  • Guru
  • Technician
Re: Too much red.. Way too much!
« Reply #1 on: April 12, 2005, 12:12:55 am »
You have a "heater to cathode" short inside the neck of the picture tube. Sometimes connecting it to a picture tube rejuvenator (a piece of test equipment sometimes called a 'restorer-analyzer') can blast the short out and fix it. Randy Fromm's website has a tech section detailing a homemade fix for this problem.
greven grevs
  • Last login:January 17, 2006, 03:24:19 pm
  • U.S. Air Force
    • The Greven Group
« Reply #2 on: April 12, 2005, 04:02:17 pm »
i have a similar problem on my monitor but it only occurs when i turn it on. i turn the game off when not in use. when i turn it on the screen is very red but after about 10 minutes it corrects itself. not sure if this is a problem or if thats the way it is. its an RCA monitor
clanggedin
  • O'DOYLE RULES!!!
« Reply #3 on: April 13, 2005, 11:58:03 am »
Mine does it intermittently it seems, but enough for me to try repair provided at Randy Fromm's site.
