Author Topic: Config?  (Read 1332 times)
mpm32
  • Cheesecake Master
  • Last login:November 20, 2018, 09:25:14 pm
Config?
« on: November 19, 2002, 09:42:26 pm »
Just getting ready to build my cab and I started playing around again with mame32 (after a long time away from it).
I used to be able to press the tab button while in a game to bring up the config menu but now it doesn't seem to work.
Any thoughts?
When I press the button nothing happens. The ~ key works for the volume attinuation.
cdbrown
  • Bowowow
Re:Config?
« Reply #1 on: November 21, 2002, 08:11:54 pm »
You need to check the std.ini file which is located in the ctrlr folder.  There should be a line in it at the top (below the chat) which is
UI_CONFIGURE            "KEYCODE_TAB"
This file contains the standard inputs for the games.  Type it in if it's different.  If it only happens in a few games then go into the cfg folder and delete the specific config files
Hope this works for you
-cdbrown
