Author Topic: XM-501 vertical collapse  (Read 1215 times)
paigeoliver
  • Awesome face!
« on: April 10, 2005, 11:39:37 pm »
I was adjusting the monitor in my newly acquired "Drop Zone 4" when it went into a vertical collapse, I was adjusting the screen size control when this happened.
The whole game is squished into an area about a half inch tall, I can adjust this height as low as a single line tall, or as tall as a half inch.
Any thoughts on which part might have failed?
Also, when I have it about a half inch tall and drop a bomb it looks like the bomb goes up and down up and down until it hits, like the image is folded over a half dozen times.
Note, the Xm-501 is a black and white monitor.
Ken Layton
  • Guru
  • Technician
Re: XM-501 vertical collapse
« Reply #1 on: April 11, 2005, 01:08:22 am »
Possibly the vert size pot gone bad. More likely dried out caps or cold solder joints particularly around the connector pins around the outer perimeter of the board.
