Author Topic: window popping up in mamewah  (Read 1943 times)
tm
  • Last login:July 14, 2006, 10:04:57 am
« on: April 09, 2005, 10:18:19 pm »
I have downloaded & installed mamewah and everything appears to be well however, when loading certian games, a black window appears - with the cursor flashing, then after that i can see the roms loading. Following that the games play as normal. Can someone please advise on how I can make the window not come up. I thought mamewah hides the windows enviroment.
tas
APFelon
  • Last login:January 11, 2026, 06:54:36 pm
Re: window popping up in mamewah
« Reply #1 on: April 10, 2005, 08:09:53 am »
Go to the emulator INI file for MAMEWah (in the mamewah/INI folder) and check your settings there.
You should see a setting that says show_dos_box. Mine is set to "auto" and I only see the DOS box if the ROMset is bad or missing. So it should look like this:
show_dos_box                              auto
Good luck!
APf
jcrouse
    • CPViewer
« Reply #2 on: April 10, 2005, 09:22:47 am »
Since you don't say whether your talking about Mame or not, beware that {autodosbox} is ONLY for MAME and NO other emulators.
John
D5A1AC
« Reply #3 on: April 16, 2005, 03:58:08 am »
I'm having the same problem but with visualboyadvacesdl. How can I hide the cmd window while that is loading ???
jcrouse
    • CPViewer
« Reply #4 on: April 16, 2005, 09:10:49 am »
I also use visualboyadvance SDL. Check out my ini file on the downloads page of my website at http://home.comcast.net/~cpviewer
Enjoy,
John
tm
« Reply #5 on: April 20, 2005, 06:44:39 am »
show_dos_box auto
Good luck!
APf
worked it out thanks. I changed auto to 'no_dos_box'.
tas
