Author Topic: Left Ctrl/Right Ctrl problem  (Read 2167 times)
BorgWarner
  • Last login:April 10, 2005, 10:42:44 am
« on: April 09, 2005, 09:36:13 pm »
My I-Pac is set to the default, P1 button 1 = Left Ctrl.  The problem I have is when I want to change the button configuration for a game, I press the Left Ctrl button and it pops up "Left Ctrl Right Ctrl".  When I go to use that button in the game it does nothing.  Same problem with button 2 being "Left Alt Right Alt"   Is there an easy solution to this?
somunny
  • Is it hot in here?
Re: Left Ctrl/Right Ctrl problem
« Reply #1 on: April 09, 2005, 09:40:25 pm »
Yeah, what's up with that?  I have the same problem.
BorgWarner
« Reply #2 on: April 10, 2005, 12:00:54 am »
Can someone at least tell me how to reset the individual game controls to the defaults?  I thought deleting the nvram file for them would do it but it didn't.
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
« Reply #3 on: April 10, 2005, 01:10:41 am »
Yeah, that happened once when I was playing with my friend. I had to push both left and right control for it to work. I don't remember what we did to fix it...sorry... :-\
I had to beat them to death with their own shoes...
greven grevs
  • Last login:January 17, 2006, 03:24:19 pm
  • U.S. Air Force
    • The Greven Group
« Reply #4 on: April 10, 2005, 02:16:58 am »
if you are talking about changing the button for each game through the config for this game then what i do is just keep re-entering that button til it clears out. for example if i want a button 1 that is assigned to lft ctrl to button 4 that is assigned ] then i just keep hitting ENTER and in putting ]. after about 8-10 times it clears out and leaves just ]. but before clearing it looks like ] and ] and ] and ] and lft ctrl.
also if you want to clear button settings just delete the .cfg for that game
BorgWarner
« Reply #5 on: April 10, 2005, 04:49:21 am »
Any ideas on why my tab button would've suddenly stopped pulling up my menus within games?   :o
Franco
« Reply #6 on: April 10, 2005, 02:34:31 pm »
Yeah I had that problem.
I deleted the whole .cfg folder and that seems to sort it out.
There may be a better way if you have got lots of custom .cfgs and you dont want to get rid of them all, but like I said, that worked for me!  ;)
Chris
    • Chris's MAME Cabinet
« Reply #7 on: April 10, 2005, 02:41:13 pm »
Seems like I had this problem if I tried to set the controls while a game was paused... try it when the game is not paused.
--Chris
--Chris
cdbrown
  • Bowowow
« Reply #8 on: April 11, 2005, 12:47:02 am »
Pausing a game and remapping causes problems.  Have you tried setting up your own ctrlr file?  Take a look here and here for info on the ctrlr files.
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: April 11, 2005, 07:04:31 am »
Delete C:\mame\cfg\default.cfg
