Author Topic: Cold solder joint... where?  (Read 1623 times)
APFelon
  • Last login:January 11, 2026, 06:54:36 pm
« on: April 07, 2005, 08:48:00 pm »
I'm looking at a G07 that I recently did a capkit in. The problem is that the right side of the monitor is fine, but the left side is faded out (washed out). I either have a bad cap somewhere, nuked a trace or have a cold solder joint somewhere. Anyone know what cap could cause something like this?
APf
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: Cold solder joint... where?
« Reply #1 on: April 07, 2005, 09:26:29 pm »
I had a problem with a bad neckboard causing the same problem.
Try reseating the neck board.
Later,
dabone
Ken Layton
  • Guru
  • Technician
« Reply #2 on: April 07, 2005, 11:25:50 pm »
Sometimes you need to manually degauss the picture tube after doing a capkit or moving the monitor.
When you put the chassis back in after doing the capkit did you remember to plug the automatic degausser back in?
APFelon
« Reply #3 on: April 08, 2005, 07:16:42 am »
Yeah, I made sure everything was in properly, and I have never seen a monitor display something like this before...
I'll post some pics sometime this evening, perhaps I didn't describe it properly.
AND I'll reexamine the neckboard mount. Thanks for the tips, guys!
APf
