Author Topic: Starting applications as a system service.  (Read 1760 times)
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« on: April 06, 2005, 11:26:47 pm »
I thought I would share this great find.
I set MAMEWAH as my shell in windows - this is nothing new.
My problem was that I needed another application to startup at the same time. And it doesn't have an option for starting as a system service.
The solution:
XYNTService
This little tool will allow you to load up any number of applications as system services. Which means even if MAMEWAH is your shell you can have any number of applications loaded and running in the background.
You can find out details about the application here, but they require you sign up for an account in order to download the application (which comes with source).
The application I use this to start is VolumeTray which lets me bind a keypress to SYSTEM volume up/down. Which comes in handy for emulators applications that don't have keypress support for controlling the volume.
Joseph Elwell.
nipsmg
  • Last login:Yesterday at 02:47:31 pm
  • ROONEY!! ERRGH!!
    • Arcadia
Re: Starting applications as a system service.
« Reply #1 on: April 07, 2005, 06:20:10 am »
NICE.
I've been looking for something like that (volume control).  I was actually going to write something based on some global keyboard hook code I'd found... now i don't have to .:)
jcrouse
    • CPViewer
« Reply #2 on: April 07, 2005, 08:00:29 am »
There is a Microsoft utility for doing this. It is distributed in the Resource Kit for Windows NT, Windows 2000 and I would bet Windows XP Pro. I used to use it in th NT days. If you search the web you may come up with it. It allows you to configure any executable (com, bat, exe) as a service.
John
jelwell
« Reply #3 on: April 07, 2005, 01:01:04 pm »
John
Or with zero searching you can just use XYNTService! ;) But the reality is that, of course, I searched already and this is what I came up with. If there's a Microsoft solution then it wasn't uncovered by google - so it must not exist. ;)
Joseph Elwell.
jcrouse
    • CPViewer
« Reply #4 on: April 07, 2005, 01:23:56 pm »
Joseph Elwell.
I figured it didn't exist and was just pulling your leg. However, incase your interested here is an article on what I assume must be vapor-ware form Microsoft, since it doesn't exist:
http://www.tacktech.com/display.cfm?ttid=197
You knew I'd respond, didn't ya,
John
jelwell
« Reply #5 on: April 07, 2005, 02:11:49 pm »
Egad! That requires you use regedit and the Service Manager on top of two programs. And, for whatever reason, the files *have* to be in a directory called "reskit"? Who comes up with this stuff? hahaha.
John
It was practically a call to arms! Actually Microsoft's solution looks a ton harder to set up (still easy enough though) but it does have the added benefit of adding an entry in the Service Manager - which, I suppose, might be a good reminder that it's there when you forget.
Joseph Elwell.
jcrouse
    • CPViewer
« Reply #6 on: April 07, 2005, 02:24:50 pm »
I don't believe it needs to be in that particular directory. Do we even have directories anymore. I think we have folders now, thanks to MS. Anyways, I haven't used it since the old NT 4.0 days but it worked pretty good then, howerer, as you pointed out I remember it being a pain in the arse to set up.
John
