Author Topic: help setting up a G400 with a Medium Res Monitor  (Read 2875 times)
zosofan
  • Last login:February 20, 2012, 02:40:58 pm
« on: November 17, 2002, 04:06:18 pm »
hey gang,
bought a G400 video card intending to hook it up to a standard resolution 25" arcade monitor.
i bought a used monitor and it arrived, surprise, it is a WG 25K5515 medium resolution monitor, instead of the U5000 as advertised.
has anyone hooked one of these up to a G400?
eye thank ewe
greg
mattv
  • Last login:June 10, 2022, 06:33:25 am
Re:help setting up a G400 with a Medium Res Monitor
« Reply #1 on: November 18, 2002, 12:59:30 am »
Theory only; but this shouldn't be too hard.
Its all about the horizontal refresh rate on the monitor, Your PC is 30ish, standard res monitors are 15 and a medium res monitor is about 22khz (I think).
So, whatever software you were going to use to force your g400 to output at 15khz you should be able to force it to send the signal out at 22khz instead and she will be a dingo.
Oh, you might want to confirm exactly what refresh rate medimu res monitors actually want, those thing are not cheap. Lucky you !
