Author Topic: SK Jukebox Question  (Read 2887 times)
surf
  • Last login:December 15, 2011, 11:43:38 am
  • I've built my own arcade!
SK Jukebox Question
« on: April 04, 2005, 10:03:43 am »
My music files are in the format of:
« Last Edit: April 04, 2005, 10:49:40 am by surf »
Surf
http://www.freewebs.com/homepubarcade
(Just a homemade arcade)
SalmonKing
  • Last login:August 16, 2007, 10:45:44 am
  • SK Jukebox
Re: SK Jukebox Question
« Reply #1 on: April 04, 2005, 11:57:18 pm »
Well, I can look at just ignoring all but the title (considering the track number is actually ignored by the program).  I would just need to put in another file naming format, however you should realise that while I can separate the title out, there may be some exceptions (i.e. if you have an artist that contains ' - ' in the name, that will be seen as the separator).
The alternative is to rename them, and there is an easy way.  Just use Tag&Rename, as that can work recursivly.
And, one other alternative is to wait for me to look at deriving the information from the MP3 tags, rather then getting it out of the filename.  This is not on my list of current things, so it will be quite some time before I implement this.
The program will resize accordingly, although I have heard that it doesn't look too great at lower resolutions like 640*480.
SK.
surf
« Reply #2 on: April 06, 2005, 02:56:59 am »
Phew...renaming everything worked...
Have you thought of making it skinnable (just a little) to look a bit better at 800x600?  Full album view looks great, but 16 point fonts are about the smallest readable on my cab.  The bottom gets cut off on most titles...
You've made an awesome program, keep up the good work!
Surf
