Author Topic: jamma pcb voltage and current  (Read 5324 times)
kenzo42
  • Last login:November 23, 2024, 01:11:32 pm
« on: April 04, 2005, 02:22:01 am »
hi, i was wondering if anyone knows how much current/voltage a jamma board draws? i'm sure it's variable from game to game, but how about an avg. approximation?
i couldn't find this in any game manuals.
thanks.
paigeoliver
  • Awesome face!
Re: jamma pcb voltage and current
« Reply #1 on: April 04, 2005, 03:00:47 am »
They all use the same switching power supplies, that provide +5, +12 and -5 volts. The switchers run on 120 volts AC like everything else in your house.
I have a feeling that isn't what you are looking for, so it might be better if you tell us what you are looking to DO with said information.
kenzo42
« Reply #2 on: April 04, 2005, 03:23:00 am »
i need to run a load on my psu since my monitor is jacked through it. ken layton aleady gave me some advice on the resistors i should use. i was just curious on how close those load resistors would come to the pcb load.
gearguy
  • Last login:May 05, 2005, 02:09:05 pm
  • Eat more children - your population needs it
    • Masters of OutRun
« Reply #3 on: April 04, 2005, 03:35:33 am »
Well what make of PSU are you using anyway?
While the voltage remains the same - some of them have (slight) Amp rating differences.
Stop mopin', Start Solderin'!
kenzo42
paigeoliver
  • Awesome face!
« Reply #5 on: April 04, 2005, 04:19:12 am »
Pcbs vary wildly, you will use the same power supply for a teeny tiny 5" square board as you will for a gigantor stack of 3 boards that are each like 16"x24".
Ken Layton
  • Guru
  • Technician
« Reply #6 on: April 04, 2005, 10:30:29 am »
The resistor values I specified will load the power supply to a 5 ampere load.
