Author Topic: A-Pac vs GP Wiz 32  (Read 1240 times)
Tiz
  • Last login:October 31, 2005, 09:51:39 pm
A-Pac vs GP Wiz 32
« on: April 01, 2005, 11:47:09 pm »
Other than both being USB only and 32 buttons max,
how do they compare?
Hoagie_one
  • Um....whats a cabinet
Re: A-Pac vs GP Wiz 32
« Reply #1 on: April 02, 2005, 12:00:34 am »
two different animals.
Tha A-pac is used for analog inputs as well as digital inputs.  The GP wiz 32 is all jsut digital inputs.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: April 02, 2005, 08:53:08 am »
Yep,
Apples and oranges.
A-PAC is closer to Daveb's AKI than the GP-Wiz.
If you don't care about analog inputs, then:
GP-Wiz32 is cheaper - A LOT cheaper if you order one of the ECO versions.
GP-Wiz is seen as one directional (D-pad) plus 28 button gamepad.
A-PAC is seen as two directional (D-pads) plus 12 buttons each gamepads with each gamepad having an additional 16 shifted buttons available.
AFAIK, GP-Wiz does not support shifted buttons, but I could be overlooking this.
