Author Topic: Flip-top control panel-options other than hinges?  (Read 979 times)
stevodevo
  • Last login:March 07, 2022, 11:27:18 am
« on: March 30, 2005, 12:41:27 pm »
I have a flip top control panel - you know where the top flips up so I can change my j-stiks from 4 way to 8 way? :)
Anyhow, does anyone have an idea for a flip up control panel other than hinges?  My cousin has a 50's truck where the hood is on hydraulics and opens via remote.  Ok that might be a bit much for a control panel but what other possibilities are there?
Hoagie_one
  • Um....whats a cabinet
Re: Flip-top control panel-options other than hinges?
« Reply #1 on: March 30, 2005, 12:58:32 pm »
I have a metal panel that sits on 4 studs.  I hand tighten bolts to hold it down.
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #2 on: March 30, 2005, 01:47:10 pm »
There's a kind of hinge (the name escapes me) that is "c" shaped, and mounts on the edge of a surface, and works by allowing a grove in the middle of the "c" to slide along a pin mounted on the inside of whatever box or object you're working with.
If ......if that makes sense.
Signature tags are dumb.
