Author Topic: toshiba 29" monitor  (Read 3259 times)
kenzo42
  • Last login:November 23, 2024, 01:11:32 pm
toshiba 29" monitor
« on: March 29, 2005, 04:21:45 pm »
hi guys, i was wondering if someone could id this monitor. i've already been to the monitor ID website but had difficulty. there was no mention of toshiba. was it rebadged?
there's a toshiba sticker on the back of the monitor and it says this on it:
a68kju96x - written below has a 5D
e39164 - something next to it w/ a backwards L and backwards R
lr27012 - SA w/ a large C around it
plus some implosion and shock warnings.
this is from a 29" astro city (old one). it has slight "1945" burn in, if that helps at all. thanks fellas!
kenzo
updated - i just read a post from ken stating that toshiba only made tubes. is there any way of telling what monitor it is from the tube and the description. i didn't see any other stickers. i will look again though.
« Last Edit: March 29, 2005, 04:26:50 pm by kenzo42 »
MonitorGuru
Re: toshiba 29" monitor
« Reply #1 on: March 29, 2005, 04:43:40 pm »
The sticker must have been on the tube, not on the electronic board/frame as monitors don't implode..just tubes  Toshiba does not make commercial arcade monitors. They make picture tubes however.
A68 = 68 centimeter tube = 26.77 inches or it's a 27" tube, not 29.
Reading the tube will tell us nothing... need a picture of the chassis and/or any stickers on the frame or heat sinks of the boards.
