Author Topic: WG K7000 - Fuzzy.  (Read 1143 times)
Wyluli
  • Last login:February 11, 2013, 06:38:03 pm
  • Stupid Stupid Rat Creatures!
WG K7000 - Fuzzy.
« on: March 26, 2005, 08:20:37 pm »
Monitor - WG K7000 19" monitor for Double Dragon machine.
I replaced the Voltage Regulator and put a cap kit on the monitor PCB.  The monitor still has a fuzzy screen and I'm not sure what to try next.
The screen looks fine size wise etc... but it looks like there is static moving around on the monitor.  It is not wavey, but the static shifts directions.  I'm not sure how else to describe it.
Any idea's on what could be the problem would be appreciated.
Thanks again.
Ken Layton
  • Guru
  • Technician
Re: WG K7000 - Fuzzy.
« Reply #1 on: March 26, 2005, 10:36:15 pm »
Did you try adjusting the focus control on the flyback?
The original flybacks for this model are a high failure nowadays so if there's still a problem replace the flyback. It's possible the picture tube may need rejuvenation if it still won't focus razor sharp.
