Author Topic: Extending CPU power switch (Dell connector)  (Read 1386 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« on: March 26, 2005, 03:05:46 pm »
Have the stupid proprietary connector running from the power on/reset buttons on my Dell to the motherboard.  8 dif't sets of jumpers on the MB, none of them really marked.
1) Will I hurt anything by randomly shorting out two pins at a time to see which ones are the power?
2) It is a Dimension 4100, P3-733, if that helps.  Around 5 years old.
3) Is there a recommended way to splice the wires?  Or should I try to solder onto the little circuit board w/ the switches?
4) Is there an easier/better way?
Thanks.  I've read up on this a good bit and most people seem to recommend those splicing connectors.
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
Re: Extending CPU power switch (Dell connector)
« Reply #1 on: March 26, 2005, 04:09:48 pm »
1.) Probably not. I've done it many times and never had anything blow.
2.) Not really.
3.) Just unplug the power switch connector from the mobo, get a spare plug thingy for it and wire that to whatever you want the new switch to be.
4.) Yes, see 3.
Paul Olson
    • Paul's Arcade
« Reply #2 on: March 26, 2005, 04:58:58 pm »
Butt connectors will work good.  If you don't have any, twist the ends of the wires together and wrap with electrical tape.  I would actually trust a connection like this more than the butt connectors.
Paul
Dougmeister
  • Dig-Doug
« Reply #3 on: March 28, 2005, 10:00:27 am »
Thanks for the ideas.
The actualy connector has room for 16 pins, but one is solid, so only 15 pins on the motherboard and 15 openings in the "molex-like" connector.  It uses a ribbon cable in-between the connector and the circuit board that has the momentary on/off buttons.
By looking at the back of the circuit board, each button has four (4) traces that lead to the wires.
Am I better off finding  a "spare plug thingy", splicing into the ribbon cable, cramming some wires into the existing 15-pin connector on the motherboard, etc.?
