Author Topic: Looking for a Ms Pacman/Galaga type 4 way, BUT...  (Read 2281 times)
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« on: March 25, 2005, 09:31:16 am »
Looking for a Ms Pacman/Galaga type 4 way, BUT... I need it to be able to be mounted to an existing control panel. I'm using a HAPP 4 way ultimate right now (I believe that's what I bought) and I don't like it at all. Problem is, I need a ms pacman type (4 way red ball top that sits low and is very tight/short travel) that can be mounted correctly to the underside of a wood control panel.
You can see all views of my control panel here:
http://www.electricquarter.com/arcadecab/controlpanel2.htm
For reference and to see what I mean :) Thanx!
BYOAC users get 5% off with coupon code byoac5
Ken Layton
  • Guru
  • Technician
Re: Looking for a Ms Pacman/Galaga type 4 way, BUT...
« Reply #1 on: March 25, 2005, 10:13:38 am »
Happ Controls already manufactures the Ms Pac/Galaga short red ball joystick. Check out # 50-6084-1125R (around $20). It uses modern mounting bolt spacing pattern so it will directly interchange with the stick you are replacing.
whammoed
  • Last login:June 02, 2026, 10:49:42 am
  • Crack don't smoke itself
    • NiceMite
« Reply #2 on: March 25, 2005, 10:46:08 am »
I think that ones too short for wood though.  I believe Betson sells the Space Invaders/Qix one that is a little taller.  I think you have to call them to get it.
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #3 on: March 25, 2005, 11:07:53 am »
There is a seller on Ebay who sells the Ms Pacman/Galaga reunion joystick with custom made longer shafts.  These are designed to be used in a 3/4" wood panel.  I have one of these and am very pleased with it.  Here is a link to the "Buy It Now" auction:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=13718&item=6163860706&rd=1&ssPageName=WDVW
The auction description says it uses a Happs SUPER base, but it is the same Super base used in the reunion stick (with a diamond shape restrictor cutout in the base).
paigeoliver
  • Awesome face!
« Reply #4 on: March 25, 2005, 06:40:06 pm »
That is probably just the Qix one.
You can also simply mount an unmodified Super handle onto a Reunion base, it works perfectly, and you can use it in a wood panel. You can't do it the other way around though, super handle fits reunion base, reunion handle DOES NOT fit super base.
NeeBick
  • Last login:April 15, 2011, 01:14:02 am
« Reply #5 on: March 26, 2005, 01:26:08 am »
I had the same problem. After reading the forum, it seems that the Versa-Ball replacement handles from groovygamegear.com work with the reunion joystick.  It may not be as real but at least I will get a great 4-way stick that I can mount under the control panel.  Plus I can now have blue handles to match my color theme  ;D.
Borrowed from the thread:
http://forum.arcadecontrols.com/index.php/topic,27822.msg275311.html#msg275311
« Last Edit: March 26, 2005, 01:31:55 am by NeeBick »
Sylentwulf
« Reply #6 on: March 26, 2005, 11:35:57 am »
Well, I LIKE it set pretty low, and I have the area for the joystick mounts reouted out, so it's pretty thin. I think there's about 1/4"-3/8" of wood left that it mounts to.
Would one of those versa-Ball replacement handles work in the 4-way ultimate base that I have installed now? Suppose I should have thought to ask that first since the would be the perfect and cheapest solution since my only complaint is the fact that it sets too high and isn't a ball top.
Sylentwulf
« Reply #7 on: March 26, 2005, 04:14:55 pm »
Looks like the "Ball, Dark Red Shiny 1 3/8" would be perfect, and works with super and competition bases.
Actually, ya know what, I think I ditched the ultimate sticks because I don't like them, and got competition sticks.... but I don't remember what I did with the 4-way, it might be ultimate still.... Anyways.... If it works with super and competition, it should work with ultimate, no?
Paul Olson
    • Paul's Arcade
« Reply #8 on: March 26, 2005, 04:24:58 pm »
Bob Roberts sells a mounting plate for the reunion sticks.  Looks like a mini trackball mounting plate.  With that, you can mount it on your wood panel, and still keep the short stick.
Paul
Edit - I realize this won't work without peeling back your artwork, but I wanted to let everyone know these are available so they can work it into their designs before hand.
« Last Edit: March 26, 2005, 04:29:31 pm by pcolson »
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #9 on: March 27, 2005, 01:26:52 am »
Super and Competition shafts are different diameter than the Ultimates.
Sylentwulf
« Reply #10 on: March 28, 2005, 09:32:38 am »
Took another look, I know I got competition stick for my 8 ways, but I REALLY don't remember what I got for a 4-way. Is there any way to tell if it's a competition or ultimate by looking at it? What am I looking for?
Sylentwulf
« Reply #11 on: March 30, 2005, 06:59:33 am »
bump
markrvp
  • NFL Expert
« Reply #12 on: March 30, 2005, 12:05:05 pm »
The Ultimate has a washer between the E-clip and actuator.  The Competitions do not have a washer between the E-clip and Actuator.  The shaft diameter is smaller on the Ultimate, than the Competition.
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
« Reply #13 on: March 30, 2005, 06:47:40 pm »
It probably is an Ultimate if it is a 4-way.  Competitions are 8-way only but Ultimates can be 2-way, 4-way, or 8-way.
Kremmit
  • - AHOTW -
« Reply #14 on: March 30, 2005, 07:06:02 pm »
Ultimates come with a textured grip on the handle, and competitions come with a smooth grip.  The shape of the base assembly is different too, check the pictures on the Happ site.
