Author Topic: what in mame/mamewah distingushes a 4 vs 8 way joystick  (Read 2675 times)
j123vt_99
  • Last login:August 24, 2006, 09:41:12 am
« on: March 24, 2005, 04:11:11 pm »
in time, i will be building a cab and probably go with a 4 & a 8 way joystick... what do i need to do so that when  i load a game with mamewah, the appropiate joystick is "activated"
Pictures of my Missile Command  http://www.nimsu.com/mc/mc.html
GGKoul
  • Cheesecake Apprentice
Re: what in mame/mamewah distingushes a 4 vs 8 way joystick
« Reply #1 on: March 24, 2005, 04:29:34 pm »
MAME doesn't know if a joystick is in 8 way or 4 way mode.  But you can break up the gamelist in two parts, games that require 4 way or 8 way joysticks.
j123vt_99
« Reply #2 on: March 24, 2005, 04:35:23 pm »
so you do 2 different ini's? one for 4 way, one for 8?
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #3 on: March 24, 2005, 05:02:18 pm »
  No,  You wire both the joysticks to the same inputs on your keyboard encoder and they will both technically be able to control MAME/MAMEWAH at the same time.. You just use the 4 way when you know you're going to be playing a 4-way game, and the same thing with the 8-way.
  What GGKoul was talking about is making a separate list in your front end so that you and your guests KNOW when to use the 4-way and when to use the 8-way.
  Know what I mean?
-sab
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #4 on: March 24, 2005, 06:14:40 pm »
From a wiring standpoint, there is no difference between a 4-way and an 8-way joystick.  They both have four microswitches or leafswitches.  What makes a joystick "8-way" is the ability to activate two switches at the same time.
As mentioned above, the software doesn't "activate" a joystick.  It simply accepts data from the joysticks wired to the appropriate encoder inputs.
j123vt_99
« Reply #5 on: March 24, 2005, 10:06:50 pm »
  Know what I mean?
-sab
ok that makes sense.. so technically you could use the 4 way to go up and left and use the 8 way to go right (not that you EVER would)
screaming
  • Registered lUser
« Reply #6 on: March 24, 2005, 10:55:36 pm »
  Technically, yes.
GGKoul
« Reply #7 on: March 25, 2005, 02:01:08 am »
  Technically, yes.
Actually no, a 4 way will only go Up, Down, Left, Right and will not allow you to hit the corners/
j123vt_99
« Reply #8 on: March 25, 2005, 08:44:06 am »
