Author Topic: Illustrator Help - Resizing Vector Image...  (Read 1739 times)
melarky
  • Last login:July 12, 2020, 12:49:22 pm
  • If I could be any animal, I would be a llama
« on: March 23, 2005, 12:48:43 pm »
Hello,
I know Photoshop pretty well, but I am not that familiar with Illustrator.
zorg
Re: Illustrator Help - Resizing Vector Image...
« Reply #1 on: March 23, 2005, 01:22:23 pm »
use the object menu to resize (transform) your selection.
there's a check bock to scale the lines and effects.
I'm on the planning stage
melarky
« Reply #2 on: March 23, 2005, 01:50:16 pm »
Zorg,
Thanks for your help, that did the trick.
tbombaci
  • Last login:October 31, 2024, 01:32:56 pm
« Reply #3 on: March 25, 2005, 11:42:29 am »
I have gone back and started to "fix" most of my early vector stuff with regards to strokes. (all of my later stuff has the expanded strokes)
"Expanding" the stroke eliminates the problem when resizing manually.
-Tom
zorg
« Reply #4 on: March 29, 2005, 02:08:03 am »
thank's for the tip.
in order to have a proper resize without stroke troubles, I'm always used to trace the outlines as an individual layer. more work, but resizing is always accurate.
