Author Topic: 25k7191 jailbars  (Read 1334 times)
achilles
  • Last login:March 20, 2005, 02:41:55 pm
25k7191 jailbars
« on: March 20, 2005, 02:07:07 pm »
Hi guys.....question:
menace
Re: 25k7191 jailbars
« Reply #1 on: March 20, 2005, 02:16:13 pm »
can't you pull up the manual for this and have a look and see if they are installed right?  also there are typically marks on the board showing negative--were they not visible on your board?
achilles
« Reply #2 on: March 20, 2005, 02:28:27 pm »
There were 2 caps that either didn't have the marks or they were worn off....I had to make an uneducated guess.  I guess I could try to find a manual and see if that tells me.  thanks
MonitorGuru
« Reply #3 on: March 20, 2005, 03:52:26 pm »
Never Guess!
An incorrectly installed cap will either blow up (blow it's cap so to speak ;)) or ruin some other part of the monitor or simply not let the monitor work right/at all.
There should be indication on the circuit board that will fill in an edge of the circle on the top of the board. This helps you identify the polarity.
Some caps are bipolar and don't matter, but are marked as such. Most however are polar and must be installed correctly.
Find the manual and triple check them.
