Author Topic: Source for molex connectors in the UK?  (Read 2928 times)
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« on: March 19, 2005, 03:19:11 pm »
Can anyone tell me where I can get hold of those chunky molex connectors, like are used for connecting control panels?
Like this;
Grasshopper
  • Last login:Today at 03:46:37 pm
Re: Source for molex connectors in the UK?
« Reply #1 on: March 19, 2005, 04:35:53 pm »
www.farnell.co.uk
Much better company than Maplin. If Farnell doesn't stock it then it probably doesn't exist.
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #2 on: March 22, 2005, 01:45:47 pm »
Yea Maplin don't stock them. They seem to get worse and worse every time I go in there.
Unfortunately that link doesn't appear to be working :(
Grasshopper
« Reply #3 on: March 22, 2005, 02:00:25 pm »
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #4 on: March 22, 2005, 02:40:38 pm »
Thanks buddy, although the original link is working now... ???
Franco
« Reply #5 on: March 22, 2005, 04:10:04 pm »
Wow! Thats just the kind of thing Im looking for too!
Ive had a look on the site but a search for 'molex' produced almost 1,500 results under various categories.
Ive had a look in each section but cant seem to find something similar. Any chance of providing a direct link or just posting what section they are in?
Thanks.
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #6 on: March 22, 2005, 04:14:06 pm »
The reason you're probably getting so many results is because theres a company called MOLEX that makes a bunch of connectors lol.  I searched it on Mouser and got a ton of results.
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #7 on: March 22, 2005, 04:36:38 pm »
Search "molex plug" and click "Multipole".
Although I can only see the male connectors for both 12 and 15 pin. I was ideally after an 18 pin one as that's what's already fitted to my cab... And I'm not even sure they include the pins?
« Last Edit: March 22, 2005, 04:50:07 pm by DaveJ-UK »
Grasshopper
« Reply #8 on: March 22, 2005, 06:13:00 pm »
To be honest, if you don't mind soldering, you'd be far better off using Centronics connectors, which can also be bought from Farnell.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #9 on: March 22, 2005, 06:21:27 pm »
i used D25 plug and sockets for my removable panels
it turned out pretty good
just need to be able solder (not difficult just need to practice)
http://forum.arcadecontrols.com/index.php/topic,25687.0.html
got my D connectors from maplin
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #10 on: March 22, 2005, 06:31:37 pm »
Do you not have to solder these molex connectors then? I don't particuarly mind as long as it works.
All the connectors in my cab are already these molex things so it would be nice to stick to that theme if possible. The panel isn't really ever going to be removed, I just want to have something that can be unplugged for whatever reason, if only to tidy up the internal wiring.
teef two
  • Last login:November 24, 2006, 08:21:45 am
  • Mmmmame
« Reply #11 on: March 23, 2005, 08:32:53 am »
Don't know if you'd considered using RJ45 patch panels as an option
http://www.homestead.co.uk/productcategorydetail.aspx?categoryid=51406
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #12 on: March 24, 2005, 01:25:10 pm »
Again, I'd rather stick to the same theme throughout.
Other connectors just don't have that solid, chunky feeling of arcade parts... if you know what I mean?
