Author Topic: Router bit for sheet aluminum  (Read 1918 times)
mac622
  • Last login:December 23, 2011, 01:21:29 pm
« on: March 17, 2005, 02:06:01 pm »
I'm thinking about skinning my CP with 1/16" or less sheet aluminum and was wondering if anyone know of a routing flush cutter bit that could handle this thin aluminum?  I've tried several searches but haven't  been able to locate exactly what I'm looking for.  Any help would be appreciated
crashwg
Re: Router bit for sheet aluminum
« Reply #1 on: March 17, 2005, 05:04:24 pm »
Just buy the cheapest one you can find so when you ruin it, it won't bother you as much...  :P
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
1UP
  • Token Junkie
    • 1UPArcade
« Reply #2 on: March 17, 2005, 05:56:12 pm »
Be very careful with this.
« Last Edit: March 17, 2005, 06:00:21 pm by 1UP »
My other job...
mac622
« Reply #3 on: March 17, 2005, 06:05:07 pm »
Excellent advice!  Thanks.  I didn't eben think of the metal/foil  covered laminate.  Erin Go Braugh!
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
« Reply #4 on: March 17, 2005, 06:10:09 pm »
I would reccomend cutting it down and filing it instead of routing it. that laminate sounds like a good idea though.
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
Tailgunner
« Reply #5 on: March 17, 2005, 06:23:44 pm »
Be prepared for some sticker shock when you price the metallic laminates. The stuff isn't cheap.
As to the original question, do you have a variable speed router? If so, how slow will it go? When milling aluminum, you typically use speeds betwen 1000 and 2000 rpm, routers typically spin upwards of 7500 rpm which is a bit much.
Something else to caution you about, finely powdered aluminum is quite explosive, it's commonly used in making pyrotechnics, and it's a primary ingredient in solid rocket fuels. Using a shop vac to collect the dust when routing your panels could be a recipe for disaster.
