Author Topic: Swappable Panels, Box Top or panel?  (Read 1714 times)
coasternuts
  • Last login:January 11, 2010, 08:39:24 pm
  • Ouuuuch....I am not the worst game ever!!
« on: March 16, 2005, 12:48:47 am »
I am working on two possible designs for my cab.  I can't decide.  Ultimately I'm thinking I will end up with 5 panels:
1)  Trackball with 4-way joystick
2)  Tron Trigger, spinner,  + joystick(4 or 8 way, not sure.)
3)  SNK Rotarys
4)  PP driving panel.
5)  4  8-way joys, to play DnD, Gauntlet,  Smash Tv.
If I go with design 1, box top, I think it would be more work, a lot of space, and not as "intimate"  :-*
If I go with design 2, just panel,  I don't think panels 4 and 5 are going to fit.   Any pointers, ideas, help...I'm stuck!!
Thanks.
Lilwolf
Re: Swappable Panels, Box Top or panel?
« Reply #1 on: March 16, 2005, 07:57:07 am »
I have your first option.  But that was how the gauntlet cps are done.
If I had a choice, I would probably go with the second though.  Should be more stable in the end.  (no worry about sliding side to side) and you should be able to have a few - fewer clamps
paigeoliver
  • Awesome face!
« Reply #2 on: March 16, 2005, 08:03:04 am »
If you drop the concept of actual 4-player support (this will never get used unless you are under 22, or you have 3 children), then the second way will be best. Just make the Smash TV setup.
As for the steering wheels, just buy a populated Badlands control panel, it will have 2 360' wheels mounted on a metal plate designed to bolt on to panels like that. Add a pair of Happ/Atari kit pedals to the bottom of the cabinet and you will be set for 2 player driving action.
sodapopinski
  • Last login:February 12, 2011, 11:13:41 am
  • if I only had normal friends
« Reply #3 on: March 16, 2005, 10:08:05 am »
Its hard to get four people to stand and play :)
Me and my friends play four player all the time with gamepads and the tv, but to get all of them to stand is unlikely. I opted against 4-player as well.
Flinkly
« Reply #4 on: March 16, 2005, 10:12:36 am »
i'd say go with the second idea just because of asthetics.  i'm trying to work a driving panel into mine too, and i'm going that same route.  good luck with al that though, sounds expensive.
GGKoul
  • Cheesecake Apprentice
« Reply #5 on: March 16, 2005, 04:14:44 pm »
I have a 4 player setup and it rarely gets used.  My next design will be a straight 4 joystick Smash TV setup with the 2nd player joystick being Groovy Gamers 4/8 way topfires.  So I can play smash TV, battlezone and karate champ properly.
coasternuts
« Reply #6 on: March 16, 2005, 10:07:38 pm »
Of course my wife agrees going with the simpler panel as she only likes to play Ms Pacman.   :P
Thanks for the comments.  I need to cross reference my CP dimensions with Smash and others to see if I should widen my cab a little.
I still think two player Smash would be nice.
paigeoliver
  • Awesome face!
« Reply #7 on: March 16, 2005, 11:11:18 pm »
You can get a 2 player smash layout on any panel. Splat and several others had that layout on 23" wide panels.
